Motul 300 gear oil (GL4/5) > Redline MT90 .
#11
No . . . audi specifies a GL4/5 or GL4+. Mind you these are completely diff from GL4 and GL5
separately.
You're looking at the old 1998 information for the Motul Gear 300. It was reformulated in 2003.
Dave
Dave
#12
Shift feel, higher viscosity, lower wear, cost.
Motul Gear 300 feels a lot better than stock. Not as grainy when going through the gears. Its also a full group V synth. OEM is unknown but I wouldn't be surprised if its made of the same high quality stuff.
I was changing around due to shift feel and I wanted to get the initial wear metals out of the transmission.
Dave
Dave
#14
I live at 8000ft and consistantly see temps < 0 each morning, no probs shifting w/ MT90.
I switched out the stock stuff a month ago and shifting has greatly improved (but i think this might be because the oem stuff had 50k on it).
Overall, i am happy with the Redline product. I have an open mind though and would consider Motul next time i change drivetrain fuilds.
#19
Here are the properties of the Motul Fluid. If anyone wants the PDF, just email me.
STANDARDS API GL4 and GL5 / MIL-L-2105D
PROPERTIES
Viscosity grade SAE J306 75W-90
Density at 15°C (59°F) ASTM D1298 0.900
Viscosity at 40°C (104°F) ASTM D445 72.6 mm2/s
Viscosity at 100°C (212°F) ASTM D445 15.2 mm2/s
Viscosity index VIE ASTM D2270 222
Flash point ASTM D92 200°C / 392°F
Pour point ASTM D97 -60°C / -76°F
PROPERTIES
#20
NP, dug up the PDF and posted the fluid specs here. . .
<ul><li><a href="https://forums.audiworld.com/s4/msgs/2180087.phtml">https://forums.audiworld.com/s4/msgs/2180087.phtml</a</li></ul>
