My 10k RS4 clutch is starting to slip...
#23
I seem to have the opposite problem, my car is running fat as hell pretty much everywhere except cold start
![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
#25
therefor it is never reaching the point where the SAC can adjust things.
#26
when your foot is off the clutch .
so if the SAC ring is stuck @ "new friction disc" position (springs retracted fully) and the disc is worn a bit = make it just like an unadjusted pp or a really worn clutch.
when you put the NEW clutch in you should have seen the adj ring move a tinny bit when bolted down the friction disc , or moved all the way (fully extended springs) and that shows the big step in the FLW .
there is a plug on the bell housing i think ..try to look at the clutch springs through that hole.. it should give you an idea.
#27
I'm at +10% on primary and +5% on accerator pump with a few gallons of 100 Oct mixed in. I'm thinking of putting the MBC at ~22PSI for starters. I also see some spikes to 26+ on 4rth gear WOT pulls - not so good.
#28
I'm still seeing 10.5-10.8:1 at WOT.
I don't have a good spot to do 3rd gear pulls right now.
I have seen 26 PSI spikes as well.
Let me ask you this - do you get a strange drilling/whistling noise at low RPM when the boost spikes hard until the RPM's rise?
#29
The car still seems to run lean on cold start. I'm going to hook up the autronic this weekend so I can start the car with the wideband already ready to go. (I need to wire a bypass on my LC-1 so I can diagnose cold start without the power cutting out and forcing the sensor to re-warm).
edit: I also need to watch the timing on cold start.
