my bad MAF plot and the DTC's which lead to the logging...
during the track event Tomasz (it's spelled correctly) pulled these with his VAG:
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Which lead us to log this:
2 runs on the same chart. note i had to lift due to a road way obstruction on the 2nd run (on right side of graphs)...
<img src="http://www.velozt.com/elements/tech/logs/MAF-log.jpg">
and boost...
<img src="http://www.velozt.com/elements/tech/logs/boost-log.jpg">
P1130 - 35-00 - -
P1128 - 35-00 - -
and boost...
Pressure tested OK. BPV's replaced. Replacing the N75 valve (since I've adjusted it), then the MAF, followed by the FPR.
I believe the too lean codes without any pressure deviations is usually the MAF.
time to STFA for more info.
i hate being the guy who comes up with the impossible problems to fix. it was the same thing with my 300ZX TT although i had far fewer issues with that car than the S4.
branshew
06-08-2006 05:16 PM
dano-oly
18
04-19-2005 01:11 PM
maxma
12-30-2002 12:26 PM
AbnormallyAspirated
07-17-2002 12:35 PM
