My beautiful turbo whine has been replaced with a whooshing sound!
I'm taking it to the dealer tomorrow morning, but I'd be interested in hearing what everyone thinks the problem is.
I have an '01 with 930 miles on it and no mods.
Look at the hose directly behind the passenger side bypass valve. It connects to the throttle body. At first it doesnt look like an 'F' shape because the two legs are facing downward. It will split between the two legs. With a small mirror, check for shiny residue on the hose, or oil within the area. The crack is hard to see without removing the hose, so only the above symptoms will let you know its cracked.
Ned
Ned
and my turbos have not yet died. I'd say it's probably safe. If you don't feel good about
it, call for roadside, since Audi will pay for it.
oily residue in the area, loss of boost/power and the occasional limp mode would be tripped--caught the problem pretty fast, but i believe the less radical the Boost/Chip the harder this will be to detect as my boost would rise(overboost) then fall fast(underboost) in lower gears this wasn't so discernable, in higher gears it felt like a wave!this is going to be a major problem for these cars as the part is made of horrible/cheap material, it will keep breaking! after talking with innovator i made a brass vaccuum block in the shape of the F tube to replace it until an upgraded replacement is produced!
<p>donp - '00 S4 Silver/Silver
<a href="http://audizone.com">http://audizone.com</a><ul><li><a href="http://audizone.com/info/tbhose/tbhose.htm">The troublesome TBB</a></li></ul>
Technician checked TBB and all hoses and didn't find any problems. He installed VAG(?) monitor during a test drive and didn't find any faults. Boost was fine too.
Very wierd.
Very wierd.
melloimolayello
22
10-09-2003 09:47 AM
M3KILR
9
09-30-2003 06:19 PM
The R
15
11-18-2001 07:50 AM
