My car makes a loud slapping sound when cold upon startup...
like a "clackety clack" sound, sounds like the fan belt but I'm not too sure, it has a little over 50K on it now, and I replaced everything at 40k(timing belt, water pump, accessory belts, power steering pump). The sound goes away completely as soon as it's up to temperature...sound familiar to anyone? any thoughts?
I had valve-tick and if you pushed the car hard, the valvetrain sounded like a Cummins diesel.
Switched to Mobil 1 and never looked back.
What you have described is nearly verbatim what the shop manual says is the symptom of debris in the oil check valves for the upper end of the motor.
