My Ferodo DS2500 pads STILL make noise
I was told to "re-bed" them and I did, 2 times. However, the noise is still there at low speed when I break. It does not care if it's warm or cold, they still make noise.
I was told "If rebedding doesn't seam to help, remove the pads & sand down a bevel on the leading edge."
Can someone extend on this?
What kind of sand paper do I need, how fine does it need to be?
How much do I sand out, just the lip, if any?
I don't want to F it up.<ul><li><a href="https://forums.audiworld.com/s4/msgs/2702624.phtml">https://forums.audiworld.com/s4/msgs/2702624.phtml</a</li></ul>
Just got some OEM pads for the rear of my car, they are beveled on leading and trailing edges. The bevel is fairly significant, enough that you certainly notice it. I don't know if this helps you any. My pads made tons of noise until I applied lithium grease to the backside.
so I did the other side. Easy little experiment, works wonders. I used a basic file and took a tiny bit off.
MySTG3S4
09-05-2007 09:05 AM
BrianG
05-17-2007 07:37 PM
