My friend finished resurfacing my flywheel! (Pics inside) :-)
#16
Hmm, okay. Do you want me to throw this thing on the Zeiss CMM for you? It's turned as true as possible without using a torque plate to simulate the clamping force of the pressure plate. Even then, a torque plate couldn't be used for machining the pressure plate seat, so it's a moot point.
What defines it as "not a very good resurfacing job"? Please bring the tech. I saw your post where you ground the surface of a stock flywheel
for $225. Any competent shop with a vertical grinder with a rotary table like yours will charge about $80 for the service. There's no doubt a locating jig to prevent movement in the dual mass mechanism won't warrant charging $225 a pop. You weren't the first person to use this technique on a flywheel... Flywheels have been resurfaced this way since the 60's. So, where's the money going? Sounds to me like you're another overpriced Audi tuner threatened by a conventional lathe and an hour's labor.
BTW - Discoloration is undried parts wash.
The fact that Audi manufactures the flywheel using a CNC lathe and the same cutting tool kind of lends to the fact you're full of ****. Take a look at a stock flywheel. You'll see the same finish on it, as it was turned on a lathe. Another thing to ponder - there is more surface variation on your resurfacing job than mine, resulting in increased initial clutch wear from break-in. I've got 14k miles on my "hackjob resurface" and my clutch is still smooth as butter.
If you make claims, bring tech, or go home.
00 Audi S4 - mostly stock
99 Cobra - 302cid 4v DOHC GT35BB twin turbo'd terror - waiting for cams. Yes, it's fast. See it in it's N/A form:
<img src="http://gallery.trumpio.com/albums/Cobra/cutaway.sized.jpg">
kday
Audi Original "S" Cars
13
01-30-2007 12:01 PM
Sia Bani
08-27-2006 09:39 PM
eg95og
10-22-2005 11:04 AM
