My power steering is on crack....
Old 12-27-2001, 10:37 AM
System_S4k's Avatar
Default My power steering is on crack....
About two weeks ago I noticed my power steering would somtimes stop working at low speeds and when I was parked. What a PIA.... Ever try turning a 3500lb car WITHOUT power steering? Well, its getting worse... It will work fine around one corner, then cut out around the next. There are NO leaks or weird noises. I am taking the car in to the dealer next week, but do you guys have any ideas?
Old 12-27-2001, 10:44 AM
Taner Halicioglu's Avatar
Default You pump could be dying...
altho I would have expected "weird noises" to accompany that...
So your fluid level is all hunky-dory and everything?
Weird.
Old 12-27-2001, 10:47 AM
System_S4k's Avatar
Default The fluid container is the green one right?
If so, ya. I just checked it. Everything seems hunky-dory. No wierd noises at all. The power steering only seems to work when the clutch is engaged, and even them sometims it doesn't work.
Old 12-27-2001, 10:50 AM
Default Yep.. the one w/ the green cap.
hmm...
Strange Things Are Afoot...
Old 12-27-2001, 10:51 AM
Member
DrewT's Avatar
my actual rack went, worked fine at speed but parking sucked! dealer said it was fairly common.
Old 12-27-2001, 10:54 AM
System_S4k's Avatar
Ah, I'll bet thats it. Thanx.
Senior Member
Nick Gustas's Avatar
If you've ever turned your steering wheel to full lock near redline, kaboom...
Old 12-27-2001, 11:02 AM
Andy Hedin's Avatar
Geez, that would be a wild maneuver.
Senior Member
Think snow. think doughnut. easy to avoid, easy to forget.
Old 12-27-2001, 11:04 AM
System_S4k's Avatar
Default Not when you drive in a couple feet of snow. :(
I probably did it driving in the last snow we got. I had to send the car sideways to get up my steep ***, snow/ice covered, driveway. KABOOM!
Quick Reply: My power steering is on crack....
