Is it my tires or my wheel bearings?
Old 03-31-2005, 03:14 PM
daseighty's Avatar
Default Is it my tires or my wheel bearings?
Recently put my new wheels on, as soon as I was on my way home from the shop, I noticed that the "tires" were VERY loud. They are BF Goodrich KDW 2's. Now, I thought that this might be the case for a day or two until they were broken in so-to-speak. It has been about 1 week now and they are as loud as ever. Highway speeds, 20mph plus, they are unbearable. What also came to mind was, my wheel bearings. My car only has 15,000 miles and my front right wheel bearing was replaced maybe 2,000 miles ago. Is this really possible within minutes of swapping wheels?! Need some help here, please.
Pic for views
<img src="http://pictureposter.audiworld.com/80761/mike_006_640.jpg">
Old 03-31-2005, 03:30 PM
AudiWorld Expert
nyet's Avatar
Default yup, could easily be the tires
hopefully they'll wear a bit and it will quiet down, but if your alignment is off, odds are very high it might not get better, only worse.
Old 03-31-2005, 03:35 PM
S4Alex's Avatar
Default you could try a couple of things..
first...
is the noice only coming from one corner of the car? if its from all four, then it may be the tires.. if only one.. it could be a few things..
if only one, then you could rotate the tires.. swap front to back...
if its still in the same spot, then maybe it is the wheel bearings..
if it moved, could be the tires.. rims.. maybe out of balance? bent?
had the same thing happen to me.. and for me it was the wheel bearings.
Old 03-31-2005, 03:43 PM
daseighty's Avatar
Default nyet, that was my other concern that I did not mention. (m)
Car hasn't been aligned since I put the coils on or the new wheels. I know for a fact that the wheels are not bent as they are brand new. The car drives perfectly straight, but yea, an alignment is on my list of things to do. You think that could solve the problem? The noise seems to be coming from all four wheels, not one corner only.
Old 03-31-2005, 03:45 PM
AudiWorld Expert
nyet's Avatar
Default it wont fix it right away, but it will help the tires wear evenly
and MAY help with the noise, no guarantees.
Old 03-31-2005, 03:46 PM
TwinTurboTerror's Avatar
LOL, I'm in a similar boat. WTF is it about swapping wheels that brings on all these problems?
Old 03-31-2005, 03:47 PM
AudiWorld Expert
nyet's Avatar
Default well, dont forget people usually swap from 17 to 18
and less sidewall ALWAYS means more noise...
Old 03-31-2005, 04:05 PM
808Guy's Avatar
KDW-2 = NOISE
Old 03-31-2005, 04:09 PM
Member
jimdoo's Avatar
Default Your tires are yelling at you to get an alignment. If you have
recently installed coilovers you absolutely need the alignment. The car can drive straight and still be way out of alignment and vise versa.
Old 03-31-2005, 04:11 PM
daseighty's Avatar
A friend of mine has them and says they are quiet!!! I don't get it. =/
Quick Reply: Is it my tires or my wheel bearings?
