are my turbos dying?
drove out today...turbos sound like they always do when car is cold...i get that whoooosh sound...but today, it seems louder and higher pitched.
now, i also remember reading that basically "if you blow a turbo, you'll know"...so i'm guessing actually blowing one results in smoke, LOUD noise, etc.
so...does my noise mean anything, or is it just the warm-day-windows-down bug?
is to pull an IC line and check for oil. _some_ is normal (not good, but normal), but the more you have in there, the worse off the seals are...
since you've cleaned the intake pipes, or if you're chipped, you get much more blowby. The best way to check is get it up on a lift and put a long metal screwdriver on the turbine housing and listen for a grinding/scraping noise, similar to how a bearing going bad would sound.
