n00b control arm replacement question...
What's a safe location for jacking up the wheel hub assembly to ride height before tightening control arm bolts?
Thanks.
Thanks.
of the control arms to the inside of the wheel well before jacking it up and torqued the control arms at that measured distance before putting the wheel on. After installing and on the ground I torque the bottom of the shocks.
I'm planning on measuring from the center of the wheel hub to the top of the fender while the car is on the ground.
After all control arms are in place (not tightened), I'm going to jack up the hub until the distance from the wheel hub center to the top of the fender is roughly what I measured while on the ground. Then tighten.
Just put the jack under the bolt sticking out at the bottom of the upright. I have a small craftsman style jack (2-1/2 ton or something).
Leave the upper control arm inner bolts and lower shock bolt loose before you jack it up.
Just be careful because if you have stiff coil-overs jacking up one front hub can lift the entire car off the jackstands (if you have the car on them).
in a position to torque those upper-inner bolts. Unfortunately my existing socket is a long one, so I'll have to buy a short one instead. Seems like it should fit with a short socket.
Yeah, I already used the lower-front arm bolt to jack up the hub. It does get a bit sketchy! My front springs are 700lbs.
sergeyk
03-12-2009 03:46 PM
PSUEng
09-23-2006 06:10 PM
try2diy
09-10-2004 05:58 AM
Audi-90sGuy
07-28-2003 06:05 AM
