NAV+ questions
NAV+ questions
I am thinking about developing a car pc that would use a touch screen similar to the one that was posted in the A4 forum about a month ago. Before I cut my dash apart, I have a couple questions about the NAV+:
-Does the nav+ have a touch screen that can be connected to a computer (MP3, Internet, diagnostic progs...)?
-How large is the screen?
-Can you navigate outside of a CD's Area(if I want to map a point to NV from PA can I map right there, or do I have to map to way points on both maps?)
-Do I really need a CD changer with the NAV+ so i can listen to CD's or is this only when you are using the NAV+ (I would like to use the CD changer line for the computer).
-Will my phone integration still work?
-Where can I get a NAV+? (location=Phila. PA)
Thanks for all your help.
mike
mike
some answers...
- No the nav+ doesnt have a touch screen
- The Screen is 5"
- I believe you can not point to different maps
- The nav+ will play music cd's i believe
- I have no idea about the phone
- And german ebay seems to be the popular place to pick one up.
Hope this helps
- The Screen is 5"
Hope this helps
More answers
- No touch screen. yes you can connect other devices
- 5"
- If your destination is not on the map CD, you can't a easily map to it IME
- Yes, you need a CD changer if you want to listen to CDs, as the Nav + is only CD ROM, no music
- Yes, you can still integrate a phone.<ul><li><a href="http://www.tvwiz.net/navigation">Great source for Nav + info</a></li></ul>
- 5"
even more answers
As you have noticed from the other responses, the nav+ does not have a touchscreen. You can use an overlay if you are willing to take the screen apart. It is really not as difficult as it may sound.
I have my V60 hooked up to mine. It works fine except when I am playing a CD. It doesn't seem to know that the call is over and to switch back to playing the CD. I have to hit end on my phone twice or switch the nav to radio and then back to CD. I am not sure if this is caused by the cd changer and harness or the nav unit itself.
The nav+ has some benefits and some shortcomings. You will probably get more features and expandability out of an aftermarket one but it will not look as factory as the nav+.
Tech
05-01-2005 09:20 PM
Dion
05-05-2000 11:21 PM
Mark
10-19-1999 06:16 PM
