NE1 using OEM throwout bearing with clutch kits like Spec or AWE? ATTN: JasonND
the bearing that came with my Spec2 clutch is a little different from OEM and <<may>>> have been the source of a promlem I was having with the clutch. I have my car apart right now and am considering putting it back together with a OEM bearing.
My question is would the through out bearing need to be more heavy duty when used with a stiffer pressure plate or would OEM be fine?
<center><img src="http://pictureposter.audiworld.com/47919/mvc-634s.jpg"></center><p>the OEM one. I <suspect> that may have caused my clutch slave to fail... bear with me..
-The slave cylinder plunger has to travel further out to make up for the thinner TO bearing
-my slave cylinder because the plastic end broke out.. conceivibly because the piston was slamming up against it.. have pictures..
-this explains the pedal vibration that I was experiencing afte about 1500 miles with my Spec2 kit. Everything worked fine until I removed my slave cylinder and the whole thing exploded because of the broken housing..
I noticed that ECS uses OEM TO bearings in thier kits. I am going to do the same when I put my car back together..
Zold-manS8
04-22-2004 02:32 PM
BTCC A4
03-19-2002 11:29 PM
Totalled SuperChargeA4
05-07-2001 04:58 PM
