Need answer on priming oil pump after UPPER oil pan change
Does the oil pump need to be primed after the upper oil pan has been changed? When I removed the upper oil pan I had to disconnect the 2 hard pipes at the pump. When I did this, they were full of oil. Is there a way to prime the pump or just turn the car over for a while (time?) without starting it.
TIA
TIA
in the cyl through the sparkplug hole.
one would do this with a new engine or with something that sat for years .
my 1 cent.
my 1 cent.
Rolf
04-28-2007 01:22 PM
LCP
01-16-2002 10:54 AM
