Need help pressure bleeding S4 brakes?
I jsut put a set of Stoptechs on my 2001 S4 and was trying to bleed the brakes with my Motiv pressure bleeder. I filled up the reservior, pumped it to ~10lbs of pressure and then opened the bleeder screws. It is barely coming out if at all. Do I need to start the car? I seems like the master cyclinder won't open. Should I pump it higher to 20 lbs?
Please help.
Please help.
I've pumped up the Motive unit up above 20lbs, but subsequently damaged pressure gauge :-P
Even at that pressure it just sort of oozes out, not as much a squirt when you have someone on the brake pedal. We since rigged up a system to our air compressor and bleed at about 25psi off that, which works a bit better.
spiralsmurf
Audi Original "S" Cars
10-06-2005 11:28 AM
Hot90Quat
06-18-2002 11:13 AM
