Need help regarding stripped rear bolt hole for front subframe...
<center><img src="http://i109.photobucket.com/albums/n71/ryan94mustang/P1010106.jpg"></center><p>So I was trying to bolt back up the rear of the front subframe after installing new control arms, and it seems the chassis side hole or bolt was stripped. I even tried the old bolts but it wasn't going to happen. I retapped with an M12 1.5mm pitch tap (Is this the right size? Seemed like it). I tried the bolts again, but no dice. I've also noticed the following sequence:
It'll start off threading a little sloppy with some wiggle. Then it will get a little tighter until the point shown above (sorry, left side of pic is up toward top of the car).
Then it will just push through to the top and spin free.
Questions:
How is the threaded connection on the chassis side setup? Is it likely to be the culprit? If so what is a good option to repair?
Is it likely the bushing? If so, should I be able to helicoil it easily enough?
Is it just the bolt? I'm gonna stop by the dealer to get some more bolts to test.
Any help would be greatly appreciated. If anyone needs clarification let me know.
Questions:
moloveshisaudi1254
06-07-2009 09:43 AM
PhilMason
14
07-19-2002 12:40 PM
