Need Help: Window Auto Down gets stuck
I have done some searching on this issue, and have had no luck.
Situation: My drivers door window's auto up/down functionality works correctly...until the window gets to 2 inches from the bottom. Then the window stops, and i must hold the button down to get it the rest of the way down. I must then reset the system for auto up/down to work again.
I have lubed the tracks with silicone. That didnt help.
I have removed the door panel and inspect the motor/regulator/tracks. Didnt see anything of concern.
I have pushed down on the glass while it was going auto down. My goal was to see if that would prevent the window from catching 2 inches above where it should. This did nothing, it still stopped where it always has.
I have trained the window on both the up and down side, but this has not changed anything.
I opened up the window motor, everything looked correct. Nothing broken or loose.
Can anyone help me? What am I missing? Does the motor control board need to be replaced?
put the window all the way up manually (using the switch a little at a time), then unbolted and removed the motor (from the 3 torx bolts), then put it back on and re-bolted. Thing works fine now. Not sure if this will work for you, but worth a try.
Yeah i have actually read quite a few posts with people having issues with the window going up, but havent found any about it going down. I actually have removed the motor and torn it apart to look for problems. Nothing changed when i reinstalled it.
Thanks for the post!
aamirs4
04-12-2009 11:48 AM
