Need some advice on a few fault codes pleaseee =)
I'm not concerned with any of the "Catalyst" codes, or any "S2" codes.. i know i have no cats and i know one of the rear o2's isnt even plugged in. I'm more concerned with the B1 S1 o2 sensor "malfunction in circuit". Bank 1 is drivers side correct? If so thats total BULL because I changed that to zoldmans like 5k miles ago.. it cant be bad! unless something like fried it?
Also EGT sensor "short to ground" thats also bullshh if that means i need to replace it becasue i replaced both EGTs about 8k miles ago.. GRRRR.
I'm also obviously really concerned with all the misfire codes. =( It feels pretty smooth under WOT, so maybe those are from cold start? I get some hickups then, but otherwise it feels pretty fine. Is it possible I'm not feeling the misfires?
Thanks in advance guys!
-Jeff
13 Faults Found:
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 35-00 - -
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16690 - Cylinder 6: Misfire Detected
P0306 - 35-00 - -
16689 - Cylinder 5: Misfire Detected
P0305 - 35-00 - -
16520 - Oxygen (Lambda) Sensor B1 S2: Malfunction in Circuit
P0136 - 35-10 - - - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
P1458 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
-Jeff
13 Faults Found:
P0431 - 35-00 - -
P1176 - 35-00 - -
P0300 - 35-00 - -
P0304 - 35-00 - -
P0306 - 35-00 - -
P0305 - 35-00 - -
P0139 - 35-00 - -
P0302 - 35-00 - -
i get those front O2 and misfires a couple of times.......
usually coldstart, since i swapped out to the Bosch Platins about 1k miles ago. What plugs u using and were they torwued to spec?
Wrinkledpants
10
06-23-2008 07:29 AM
Seabeast11
10-26-2006 01:32 PM
Swank4
12
12-08-2005 08:37 AM
