Need some advice with Stage 3 fueling and hybrids
#13
He had zero clearance, clipped turbine wheels, ceramic coated exhaust housing, ported wastegate, etc, etc.
*-corrected
*-corrected
#15
recreate that. I believe it was something like 40F outside for that. I even have the 003 somewhere around here.
#19
Personally I think with those turbos on 91 I'd try a mini Homebrew set-up. What I mean by that is run a 19/20psi spike and hold 17/18 and no more. 91 sucks anyways so running more isn't going to really help you. And the natural taper of MBC only will work well with the hybrid when they run out of breath up top and give you a great mid-range punch. Since you aren't pushing it as hard you will get the most out of 91. If you push more, you'll not make the power no matter how much boost you push with those.
Also don't get your hopes too high, or it will drive you crazy. If you are running a mid 4 on 91 with those turbos you are doing well.
