need some help!!!
<center><img src="http://i149.photobucket.com/albums/s57/2kblacks4/bolt.jpg"></center><p>the idle wheel pulley bolt snapped off when i was trying torque it to speck. ****ing auto zones torque wrench was broken and i never heard it click. the pin is out was wondering what to do? should i take it off or try and compress it back down if i even can? i am freaking out i dont know what to do.
reverse threaded bit that looks like a dull drill bit. You drill a hole in the middle of the bolt using a center punch to start it. then you hammer the easy out into the hole you drilled and twist out, like you're removing a screw. They work like a champ.
Once the pressure is off the bolt should be pretty easy to get out (vice grips) unless its totally snapped off in the block...
btruby
07-18-2007 05:55 PM
Catamount90
12v V6 Discussion
05-07-2007 06:44 AM
