need some help...bird **** on the car
Old 06-10-2002, 02:22 PM
Junior Member
tlmack53's Avatar
Default need some help...bird **** on the car
just happened today and it seems that its already into the friggin' paint. i can't f*ckin' believe it...just washed it last night, got **** on today and now it seems to be there permanently. any helpful hints or advice would be appreciated. TIA
Old 06-10-2002, 02:27 PM
Junior Member
Black2001S4's Avatar
get a clay bar and start rubbing... plus get a gun and revenge
Old 06-10-2002, 02:56 PM
Junior Member
Bi_Turbo_WI's Avatar
I just use a "hot compress" and let it sit on there for 30" or so...then it loosens up...
Old 06-10-2002, 03:30 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default I'm assuming you washed it out, and there is an etching left behind?
If you haven't washed it out, do that first. Spray it with some quick detailer, let it sit 15 minutes, then attempt to wash it (it should be loosened up by then).
To remove the etching, try One Grand Special Touch, or 3M Imperial Hand Glaze mixed with a dab of P21S Multi Surface Finish Restorer. Wax when you're finished.
A clay bar is unnecessary here. The gun...unless you make it your mission in life to eradicate every bird from this planet, it's probably pointless.
Old 06-10-2002, 03:42 PM
MarkFank's Avatar
Don't rub it off! Slowly soak it w/ warm soapy water until it softens, then wipe it away.
Old 06-10-2002, 03:52 PM
Junior Member
tlmack53's Avatar
thanks...i just talked to car care specialist and they said 3M imperial hand glaze...
Old 06-10-2002, 04:12 PM
Senior Member
JBear::FATS's Avatar
Default If the scratches are anything more than swirl marks, IHG will have a tough time
removing them. If we are talking about a baked in outline then IHG should be fine.
Old 06-11-2002, 12:53 AM
neoprufrok's Avatar
Default Use a quick detailer...
To soak the first. Hot compresses might actually remove the wax underneath if your wax is carnuaba based. AFter soakign with quick detailer spray off with water low pressure, then wipe off.
I have had great success with this... wipe off with either 100% made in usa cotton or the new microfiber.
Stonehenge
25
09-15-2006 04:02 PM
2PUTT
15
12-19-2005 03:34 PM
AUDIOZ A4
Auto Detailing Discussion
11-07-2002 07:52 PM
SameerP
05-29-2001 09:20 AM
Quick Reply: need some help...bird **** on the car
