need some help...bird **** on the car
just happened today and it seems that its already into the friggin' paint. i can't f*ckin' believe it...just washed it last night, got **** on today and now it seems to be there permanently. any helpful hints or advice would be appreciated. TIA
If you haven't washed it out, do that first. Spray it with some quick detailer, let it sit 15 minutes, then attempt to wash it (it should be loosened up by then).
To remove the etching, try One Grand Special Touch, or 3M Imperial Hand Glaze mixed with a dab of P21S Multi Surface Finish Restorer. Wax when you're finished.
A clay bar is unnecessary here. The gun...unless you make it your mission in life to eradicate every bird from this planet, it's probably pointless.
To soak the first. Hot compresses might actually remove the wax underneath if your wax is carnuaba based. AFter soakign with quick detailer spray off with water low pressure, then wipe off.
I have had great success with this... wipe off with either 100% made in usa cotton or the new microfiber.
JaminTT
16
01-20-2003 08:54 AM
SameerP
05-29-2001 09:20 AM
