Need some help removing the radiator...
So in yesterdays heat I was wainting on the gas station for the guy to show up to put gas, so in about mins or so i notice that all my coolant is leaking and after the coolant light came up. Now I'm trying to figure out what happened, but the coolant seems to be leakign from inside the rad support and can't see, so I removed the A/C condenser, but I can't seem to figure out how to remove the radiator. There are two plastic caps on top, easily visible when the hood is opened, thats seems to be attahced to the radiator; Am I supposed to removed those? and how?...
thanks for the help.
<ul><li><a href="https://www.audiworld.com/tech/eng34.shtml">https://www.audiworld.com/tech/eng34.shtml</a</li></ul>
it shouldn't come off, but if it did you'll need to get a new clip. the hose won't stay on without it.
