New best fats time with my AWE RSK04 kit 3.80
Only tweaks to the kit was upping the boost. Running on the stock N75 valve i ran a fats of 4.05. Click on the link and you will see the boost changes i made. Anyone care to comment on my boost logs?
EDIT: all these logs are with MBC and TCD installed.<ul><li><a href="http://fastfour.net/logs/boost.htm">http://fastfour.net/logs/boost.htm</a></li></ul>
AudiWorld Expert
Todd just got finished explaining that the kit makes a peak 19-20psi.
Curves look good though - oh, and nice graphs - I've seen them somewhere before
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
AudiWorld Expert
I think GIAC did once on some software, but then had overboost issues, and changed this to try to address them - at least that's my fuzzy recolection.
Here's APR, assuming this is what you were talking about:
<img src="http://ctny.audiworld.com/mark/s4/misc_data/logs/apr_stg3_tbox_mark_v2_noseats_49f/index_files/Typical-3-27-2006_8-22-40_AM_v2_p0t_vs_p3t_40f_29519_image012.gif"><ul><l i><a href="http://ctny.audiworld.com/mark/s4/misc_data/logs/apr_stg3_tbox_mark_v2_noseats_49f/">http://ctny.audiworld.com/mark/s4/misc_data/logs/apr_stg3_tbox_mark_v2_noseats_49f/</a</li></ul>
running APR stg2 for most of the time I didn't catch that. The few mos I've run X in mine I noticed some difference between versions, most notably the earlier code ramped like the APR curve iirc and the 2003'ish ramped like RSAVIPERs. Wondered why the TB ramp was so slow on their Stg2/Stg3.
