New Fault Code
#14
I will do the log tomorrow, but every time I´m at WOT the car behaves different
sometimes it does the following
WOT: boost to 20psi, drops about 1 second to 15psi, then I hear like a sound of a "blow off valve" (pressure release)and the it dropsto to3 or 4 psi.
Then when I try again, it only boosts to about 10psi, and comes down to 5psi.
a couple of shifts later, the "cycle" starts again.
I will try to to the logs several times
thanks
thanks
#15
from your logs you sent you have overboost throttle cut with sometimes going into limp mode.
It also looks like you are at altitude (4500 ft?). Requested boost is around 15 psi or so max (looks like K03 chip), but see some actual boost up 20-23 psi which is not good. You need to find the cause of your overboosting TC. Could be a number of things; boost leak, DV valve, N75, waste gate, torn TBB, etc. I would defineatly pressure test first.
Bruce
Bruce
#16
I will buy a new N75, thats the only thing I havent done.
I have pressure tested, no leaks
TBB is a new OEM,
wastegates have been checked, OK
I will also try using stock DV valves instead of the forge ones.
Thanks
TBB is a new OEM,
Thanks
MCPaudiTT - DEFCON 1
08-08-2007 07:18 PM
