New Updated B5 S4 guide
#12
For example, one of the things that new owners didn't really deal with but is pretty common on our cars at this age is the aix. coolant pump dying. I want to get stuff like that in there for the most recent owners of these cars.
#13
Right now I'm planning on dividing the guide into 5 sections as follows (these are in no particular order):
Mods - everything from boost gauges to GT builds
Common Issues - Mechanical failures and quirks of the B5 S4
n00b FAQ - answers to the questions we've all asked at some point and which get re-asked every single day without fail.
Component Locations - illustrated guide to finding important engine components
Where to get stuff - good vendors for mods, tunes, and so on
Did I miss an important section?
#16
Mods:
DV’s – Diverter Valves: also know as BPVs (bypass valves)
The stock diverter valves are diaphragm based and tend to tear internally. The likelihood of failure increases with age but also with increased boost. This is not an overly expensive upgrade and requires only basic tools and mechanical skill to complete.
Popular replacements fall into two categories – Diaphragm based and piston based.
The piston type tends to be more abrupt but is considered better for high output applications because it is less susceptible to failure from high temps and boost levels. The piston types do require occasional lubrication – typically it is best to do this whenever you change the oil, which should be between every 3k – 6k miles. Just spray a little WD40 into one of the openings.
The diaphragm type is ideal for a stock or moderately modified car and for those who want to keep engine operation as smooth and silky as possible. All of the options listed below have been widely used on the 2.7tt so you can be confident about their reliability.
1. 710N DVs used on Audi TTs. These are significantly more reliable diaphragm design from the OEM Audi Supplier.
2. APR R1 – a performance diaphragm design that can handle higher temps and boost.
3. Forge 007 – Piston based aftermarket DV. You can purchase stiffer springs to adjust the performance of the piston.
4. Bailey DV30 – A popular upgrade for the 225hp Audi TT and to a lesser extent the 2.7tt. This is a performance piston style DV and is the DV that I use.
#17
Well, it might be a bit early for true restoration projects, but plenty of people want to know the differences between the various model years. Unfortunately, I am not all too versed in the minutia - I know from experience that the control arms differ, the aluminum uprights were replaced after 2000, ESP was added in 2001 and the Bosch MAF was replaced with the Hitachi. I will need to do more searching or get some input to get beyond that.
Updated: Wheel album guide. You see something not there, post a picture and tell size make and model
2000SForce
09-25-2005 11:21 AM
Neon01
30
03-09-2004 12:24 PM
