Newbie w/ a 2k b5, help w boost?
#14
They are still roughly 50$ upgrade fee even with Flashloader. Had a couple of different GIAC-X versions and then GIAC 3-. Ran 2 program flashloader versions (stock and pump).
Bruce
Bruce
#16
Today was a great surprise when I went to order a VAG COM online and realized that AWE's headquarters are less than 10 miles from my house over in Willow Grove PA!... So I took a trip over there and picked up a KII-USB unit and ran the auto scan. I'll just paste the results here, the interesting one is the N75 which explains a lot of what was going on earlier in this thread, and it's exactly what people suggested was the culprit. Any advice on what to do with the other fault codes? The ignition does seem to take longer than usual to fire, I sometimes have to blip the throttle to get it to fire up quickly. The guys at AWE were awesome btw and very helpful, as was EdyJun's site. Here are the results..
Thursday,18,June,2009,17:50:37:51498
VCDS Version: Release 805.4
Data version: 20090602
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 A
Component: 2.7l V6/5VT G 0003
Coding: 06611
Shop #: WSC 03160
1 Fault Found:
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D57
Coding: 00160
Shop #: WSC 06325
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06325
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 DX
Component: B5-KOMBIINSTR. VDO D17
Coding: 02264
Shop #: WSC 03109
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16172
Shop #: WSC 10001
1 Fault Found:
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 40322
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06325
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 06325
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End ---------------------------------------------------------------------
N75 valve replacement time, or is it something electrical? I'm going to pull the ECU as soon as all these diag scan things finish and I dont feel the need to play with the VAG COM anymore to check if there's a sticker or anything indicating exactly what chip is powering this thing. Thanks guys.
Coding: 06611
Shop #: WSC 03160
1 Fault Found:
Shop #: BB 24334
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
Coding: 02264
Shop #: WSC 03109
1 Fault Found:
Coding: 16172
Shop #: WSC 10001
1 Fault Found:
00956 - Key 2
Coding: 00101
Shop #: WSC 40322
Coding: 00012
Shop #: WSC 06325
Coding: 00115
Shop #: WSC 06325
1 Fault Found:
00-00 - -
#17
Check your N75 cables and make sure the connector is on tight and wires are ok.
This error could be a bad N75. Have you logged the boost and N75 duty cycle?
#18
N75 cable/wires seem ok visibly and the connector is on there tight. Where in the VCDS is the logging... would I go to Applications / Controller Channels Map, then log #115 to log boost?
Did a Darintake setup last night (K&N panel filter, thank you PO!) and fog light delete since one was busted anyway, and I ordered a set of 710N's since the stockers are still on there after 9 years and 69k. I just ordered a new n75 as well so hopefully that takes care of the problem the VAG COM found, but I'd like to figure out how exactly to log the two things you mentioned there MySTG3S4. The online VAG COM manual wasn't much help. fwiw the ECU had no sticker/markings on it.
edit: i replaced the n75, it fixed the problem immediately. yay!
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
#19
yea when you chip its usually ideal to go and throw in 710n's at the same time. The N75's wont last on a chipped S. That should fix your issue although it wouldnt hurt to run a pressure test to make sure you don't have any bad check vavles, etc.
#20
The N75 valve is not going to fail because you chip the car. My car has been boosted beyond stock for nine of its ten years and is still running fine with the original N75. Parts fail, some due to higher boost, like the TBB, but the N75 doesn't fall into that category.
Hi all, Can anyone assist with feedback on a used car purchase? yes its a B5, I know, but this is my
B56
20
09-01-2007 09:45 AM
Chris.Ranch
NorCal Discussion
06-21-2006 11:58 AM
BSK auf Arbeit
06-02-2005 12:02 PM
