NGK Iridiums cured my full boost misfires where the Bosch Platin F5DP0R were flaming out.
I was getting intermittent flameouts under full load through the lower gears with the Bosch F5DP0R plugs during the high boost spikes. ASP K04 fueling, 24+/- psi tapering to 22+/-psi file. Just put in NGK Iridiums BKR6EIX in a desperate attempt to cure the misfiring. Voila, several rips through the gears, no flashing CEL misfiring like with the F5DP0R's.
One question, does anyone "in the know" have a suggestion as how long it is OK to run these plugs (replacement interval).
Thanks,
Thanks,
I have had the same plugs in mine...albeit I am pretty much stock...however
I have noticed a slight improvement over the stock plugs...The NGK Iridiums were also very good to me with my last car (Nissan 240SX).
