No boost Stage 3(1 year no problems), this ones confusing.
Well I my winter car didnt like me anymore so I had to break out the S4 up here in cold a$$ wisconsin. I have been running a MBC on the FULL(everything awe offers) stage 3. I did the install on it, but cant figure this one out.
I have checked all the hoses/wastegate lines/intercooler tubes and I CANT find any boost leak. The car only makes about 1or2 psi now. I can hear the turbo spool DOWN and you cant hear it spool up. Its almost like there isnt enough air for the turbo's.
I have cleared all CEL and disconnected battery thinking it might be some weird sensor and still no luck. So I know its not the boost tubes, wastegate lines, intake plumping, or the MBC(removed it). The car doesnt misfire or anything. Also I notice that there is a little bit more oil reside coming fromt he exhaust @ startup. I usually runa bout 23ish psi, settling @ 21.
Any ideas? Car runs fine, I have all silicone hoses on the intake track.
Thanks
Thanks
AudiWorld Expert
after the turbos and before the boost gauge. Even if you didn't want to make any boost, the wastegate springs are set around 4-5psi, so you would still see that much boost before the wastegates opened. If you're only seeing 1-2 psi, it sounds like there's a leak somewhere before the boost gauge sensor.
Is it stumbling at all at idle?
I'd pressure test first, after a visual inspection to see if any IC hoses are off, etc
On my S4, I once had a big *** intercooler leak and the car would BARELY start, but would quickly die after a second or two.
IC hoses are fine...I am going to jack the car up tonight and take a real good look @ it. The car doesn't stumble @ all on idle and it turbo sounds normal on spool down...
thanks for input though. Maybe a crack in my Y pipe? but that would lead to misfiring...
im guessing i am completely screwed. I ran it a little higher in the RPMS to see if it owuld produce any more psi and a cloud of gray smoke came from my exhaust. I dont think the shaft broke and this totally sucks because i bought a house and am completely broke. Any idea, after the year it takes me to pull out the engine and turbos, where I should send them out to get rebuilt. I takes me over 1.5 years to save 1000 bucks. Single home owner isnt cheap
