Not sure if this is a boost leak or not. ***Sound Clip Included***
I have upgraded DV's and just replaced the TBB the week before. Let me knwo what you think.<ul><li><a href="http://youtube.com/watch?v=Nh0zLnMzmiY">http://youtube.com/watch?v=Nh0zLnMzmiY</a</li></ul>
i had a similar noise when i pressure tested. one of the TBB clamps pinched my TBB
making that noise.. have you done a pressure test ? first thing i would do is loosen, adjust, tighten TBB clamps. If that doesnt work, pressure test, and if you dont find any leaks start getting into turbos and power steering pump.. but i doubt that.
Sounds like vibrating waxpaper. What kind of DVs? Could one be defective? I would pull the dvs
and test them. Did you upgrade dvs b/c the old ones failed? If you still have the old ones and they're good, try popping them back in.
I doesn't really sound like a straight boost leak nor does it sounds like a bad waterpump/ps pump. It sounds like a vibrating diaphram.
They're Forge DV's, i replaced pprior to getting chipped, I might need to re-grease them, but ...
the sound i am hearing isnt coming from there, it is coming from right in front of the driver side turbo, maybe underneath it. I'm pretty sure it isnt thedentist drill noise.
Z-Tuned (Alex)
11
03-17-2007 02:03 PM
Z-Tuned (Alex)
12-16-2006 08:12 AM
yzracer
16
06-05-2006 12:43 PM
ess_fawr
07-21-2004 06:54 AM
vonSol::kinkS4
05-06-2004 06:19 PM
