O2 sensor codes...is this just one bad O2?
16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
P0138 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
17585 - Bank2: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1177 - 35-00 - -
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
What does control limit reached mean? does the resulting CEL mean my timing is being pulled back?
P0138 - 35-00 - -
P0130 - 35-00 - -
P1177 - 35-00 - -
P1176 - 35-00 - -
Are you still boosting like normal? Just because the CEL is on, doesn't mean that you are in limp mode. Do you have a boost gauge?
Did you just put in DPs or anything, messing around in there?
yes, still boosting...but feels faster after I clear codes...but just by a little.
this started happening after my clutch got installed. afraid the might have gotten grease on a sensor, or maybe clipped a wire...but not sure how to check that...I'm not as mechanical as I'd like to be
to where you got it done and have them check the 2 sensors and wires on the passenger side dp. It will only take a moment and give you a little peace of mind.
If you are still under warranty, take her in and have the dealer replace/check the o2s.
no boost gauge?
no boost gauge?
infestdead
07-14-2014 07:23 AM
rickyS4
07-31-2006 11:13 AM
CARSNPLANES
04-28-2005 08:53 PM
