Octane info (long)
Octane info (long)
If anyone is interested, I pulled this info off an NSX discussion site:
"Octane boosters offer little help in the quest for higher octane. Most popular street-legal octane boosters claim increases in octane ratings up to five points, and those boosters intended for off-road use only claim up to seven points. That's a lot of octane to hope for simply by pouring an additive in a tank. Sunoco told us that before they launched their GT-100 Unleaded retail pilot program, they wanted to be sure that a 100 (R+M) / 2 octane street legal fuel would be of value, and that enthusiasts would not be able to get the same (or better) results using an octane booster. Nine of the most popular retail octane boosters were put through a series of tests to determine where the consumer could get the most bang for the buck. The test results were verified by an independent testing facility, using several brands of regular unleaded and premium gasolines, just to make sure everything was legit.
According to Mark Borosky, Vehicle Test Engineer for Sunoco,"Of the nine octane boosters tested, none showed a significant increase, and one actually lowered the octane number of the test gasolines."Testing repeatedly showed a maximum increase in octane of 3.5 points by only two of the six street legal octane boosters when the recommended treatment rate was blended with lower base 87 octane gasoline. The best the remaining four products could muster was less than a one point increase. "While clearly no one would actually use an octane booster in a low base octane fuel, we wanted to give the manufacturers the benefit of the doubt relative to their claims of five-to-seven point increases," explained Borosky.
When tests were performed using 93 and 94 octane fuel, even the two best products from the previous tests produced a disappointing 1.5 to 2 point maximum increase. The remaining four street-legal octane boosters showed less than a .5 point increase. Those products designated for offroad use only didn't fare any better than the street-legal products. Subsequent tests where the dosage of octane booster was doubled, tripled, and even quadrupled produced only minimal improvements in octane, regardless of the base octane number of the test gas. In fact, quadrupling the treatment rate of the most powerful additive produced only a 3.5 point increase in octane when added to 93 premium, resulting in a cost of $3.25 a gallon."
taken from <a href="http://www.nsxprime.com/FAQ/Miscellaneous/FuelAdditives.htm">NSX Prime</A>
Chuck-S4
08-25-2006 01:42 PM
kraeburn
28
04-16-2004 11:41 AM
Roughedgez
11-23-2002 10:25 PM
SmokeyA4turbod@ebay
09-19-2001 09:03 AM
