OEM Valeo HID install on a Canadian (Halogen) headlight. Installed; with pics and short write up.
Old 03-11-2008, 09:53 AM
Hobag's Avatar
Default OEM Valeo HID install on a Canadian (Halogen) headlight. Installed; with pics and short write up.
I played with the idea of aftermarket HID's for my halogen headlight retro-fit project, but decided that I wanted to keep the engine bay as clean and OEM as possible. I know a few other Canadian B5's that have gone the OEM route, but there wasn't a solid write-up in the archives or tech articles that described how easy and (most importantly) how clean the OEM method is.
So this small write-up is for any present or future B5 owners who are unfortunate enough to not have HID's to begin with.
Before you start, all Canadian B5 S4's use DRL's. Disable this before you turn on your newly installed HID's for the first time. The write-up in the Tech Articles can be found <a href="https://www.audiworld.com/tech/ext7.shtml">here</a>.
First, remove headlight and all halogen bulbs and wires.
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0082.jpg" border="1">
Then test fit the ballast into position and either measure or guesstimate (I measured with a small ruler)where you need to cut out the openings on the housing for the two connectors.
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0092.jpg" border="1">
Another pic of ballast for reference:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0093.jpg" border="1">
Then either dremmel or cut out your marked areas. If dremmeling, small plastic pieces will fall into your housing, so be aware of that.
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0087.jpg" border="1">
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0089.jpg" border="1">
Test fit again to see if the holes line up or if you need to make them bigger.
You can do the following at anytime; crimp these metal tabs onto the open ends of the power connector. These are what you will use to connect to the original plug that connected onto the orginal halogen bulb.
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0090.jpg" border="1">
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0091.jpg" border="1">
Now, either connect the two connectors onto the ballast before you install onto the housing or you could attach the connectors after, but if you have large hands I suggest you do the former. I attached them first and fished the wires into the housing before installing the ballast.
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0095.jpg" border="1">
^^You can see where the silver connector comes out of the cut hole.
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0098.jpg" border="1">
^^Here you can see where the power connector wires come through.
Next you can do at anytime; the OEM "kit" that I bought came with a H7 adapter washer. I'm sure you could just rig it so you don't have to use this, but I used it anyway. Whether you use it or not, you will have to cut small slits in the plastic on the xenon bulbs to make it fit into the halogen hole, the adapters just make it easier for you to do this as it gives you a guide so you know where to cut exactly. I used a dremmel with cutting disc.
Here's the normal unmodded bulb:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0103.jpg" border="1">
Here's the modded bulb with the two small slits cut out:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0085.jpg" border="1">
Here's the bulb with the adapter washer. You can see where the cuts line up with adapters':
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0084.jpg" border="1">
Now, stick the bulb (with or without washer) into the hole and it should only fit one way. Bend the two teeth (where it secures the clamping mechanism)on the bottom of the socket down a little bit. This will make clamping easier afterwards:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0105.jpg" border="1">
Now stretch the clamp slightly, over the bulb and clamp into the teeth:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0106.jpg" border="1">
Connect the metal tabs to the power connector from housing:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0107.jpg" border="1">
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0108.jpg" border="1">
Connect the bulb harness onto bulb:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0112.jpg" border="1">
Another pic for reference:
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0109.jpg" border="1">
Throw all your other bulbs back in if you haven't already and reconnect all the wires. Put the plastic covers back on, reinstall the headlights onto your car and you're done!
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0113.jpg" border="1">
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0115.jpg" border="1">
Now enjoy your new found vision and clarity!
<img src="http://i200.photobucket.com/albums/aa143/hobag23/HID%20Install/DSC_0130-1.jpg" border="1">
If anyone wants to know where I got the kit from, I have included a link to their online store (they're on ebay as well). Their service was great, shipping (to Canada no less!) was fast and they stay in constant contact with you. I was surprised how complete the kit is, it even came with all the hex pattern screws to secure onto your housing and the little spade connectors for your wires. Definitely check em out if you plan on doing this mod (especially if you're in Canada eh!).
Old 03-11-2008, 09:55 AM
spa
Member
spa's Avatar
nice write up!
Old 03-11-2008, 10:04 AM
Senior Member
a4tisâ„¢[Bye Turbo]'s Avatar
2nd
Old 03-11-2008, 10:05 AM
HIS4's Avatar
Default FYI: The store HID Concept is the same guy that goes by the name akinaboy on ebay.
Very reputable seller and well known for great deals on HID replacement lamps.
Old 03-11-2008, 10:15 AM
Rudy H's Avatar
Default What I found with HID kits - get a lifetime warranty and pray the person is around
Been 2 years now, and I think I went through 6 bulbs between my S4 and Mazda3. Would have cost around $600 in replacement bulbs alone.
Old 03-11-2008, 10:22 AM
Cypher2k's Avatar
can you link the tech article?
Old 03-11-2008, 10:47 AM
Hobag's Avatar
Added. Thanks for the tip.
Old 03-11-2008, 11:24 AM
Bruno_S4's Avatar
Nice job Hobag
Old 03-11-2008, 12:10 PM
Carmine_S4's Avatar
Nice! Clean as usual. I like my junk in the engine bay...my motto is "as long as it works"
Old 03-11-2008, 12:24 PM
Hobag's Avatar
I usually like my junk in the trunk.
Quick Reply: OEM Valeo HID install on a Canadian (Halogen) headlight. Installed; with pics and short write up.
