Oh Coilover Gods, how do you adjust them.
Just got my H&R Coilovers on friday, and got to drive the car today (long weekend away with my wifes jeep ). I looked at adjusting the height on them as they are set all the way up. I used the factory jack (seems kinda skimpy) and took one wheel off. Do you loosen the lower bolt and then move the large one down to it? Are they harder then hell to move? Clockwise or counterclockwise to loosen? Any tricks in doing this? Is there only one spring per strut? Do I need a better jack for this, so I don't squash myself? Should I just let a professional do it?
Thanks for any and all insite!!!!!
Doug
Doug
Not too hard...
I didn't use jackstands since I wasn't climbing under the car. I used a 3-ton floor jack.
You'll need to loosen the lower perch (nut) and adjust the height by rotating the upper one. Clockwise should bring the height down.
What I did was make a mark on the perch (in one of the notches) so I could count the number of turns and get the height even (laterally).
When we installed the H&R coilovers initially, we used some spray lubricant to make the adjustment easier. You'll want to wash it off when you're done so road grime/dirt/sand doesn't stick to it.
My experiences....
With my H/R coilovers, I found that there is still too much compression on the spring to just turn the collars unless you are a WWF wrestler so you will need a spring compressor to loosen the unit. Do it slowly and try to use a jack stand since the factory jack has been know to fail!
Nononono, use the H&R supplied spanner wrench, you do NOT need to compress spring! [more]
Adjusting is very simple with the right spanner wrenches. It takes me only minutes to do each wheel. Jack up the corner, remove the wheel, and use the spanner to move the perch and up and down. I don't recommend the stock jack other than when you are stuck somewhere, buy a small floorjack for home use, and a set of jackstands.
Boston Driver
22
01-17-2005 04:44 PM
DennisD
04-14-2002 05:25 PM
S4@last!::Now B7 RS4
11-14-2001 05:25 AM
GTEJR
11
09-20-2001 11:46 AM
So when coilovers (i.e: h&r) are ordered from a vendor, is the ride height pre-set from the factory?
nick n
09-20-2000 05:06 PM
