Oil consumption - used over a quart during break-in - anyone have this rate of consumption?
I check the oil the other day and noticed I was a bit below the 1 quart low marker, not so good. This was with about 1300 mi on car. This seems like rather high consumption.
Hi,
First, Audis use oil, generally. My last 3 (1/4 million on each) used 1 qt/2.5k from new to the end.
Two, my S4 used just under 0.5 qt in the first 1k miles.
Three, when i added, it was just below the bottom of th hash ("too low"). I added just less than 1/2 qt and OVERFILLED it. So I'm not sure what the 1 qt low mark is, i dont think there is one. more like a 1/3 low mark.
Usage should decrease if you brak it in well.
Grant
Grant
Just has my car serviced, 50 km later oil warning light empty. Mmi says low, need to add 1 l. Car normally using 1 l per 1500 km and mech cannot work out was is wrong. Also had to replace could and 4 x spark plugs as foiled (were only 2 months old). $2k spent and still no fix. Help
On the oil front - my 2018 Q7 is the first audi that I've had that "uses" oil - I know that most Turbo motors use more oil than most normally aspired ones - that should be considered. The 2.0 in my S3 has not used as much oil - again this is anecdotal.
