Oil Drain Plug Washer - Oil Leaks
2000 S4 with 41,000 miles. I change the oil myself every 5k with Mobil1 0w30, or 5w30. The o-ring(washer) that comes with a new drain plug does not come off. Naturally it gets beat up after 3-4 oil changes and then you need a new plug and washer. Does anyone buy the washers seperate and if so, where, and how did you get the old one off without damaging the threads? I seem to leak a little oil from the drain plug.
Thanks
Thanks
it's thicker than a crush washer, and yes, you cannot remove it. Some questions... Why did you buy a new plug? How did the washer get "beat up"? Mine's not showing any wear, and I change the oil myself.
Rory
'01 S4
Rory
'01 S4
Ghant TMK
17
04-04-2003 08:02 AM
Type44Q
03-21-2003 08:42 PM
BrianN
05-05-2000 03:29 PM
