Oil drops on garage floor...? anyone notice this also...(m)
had the car parked for a couple weeks and hadn't driven it anywhere. This is the longest it has probably sat undriven since i purchased the car one year ago. Well, i noticed 2-3 small drops of oil on the garage floor...is this normal?
Did you have your oil changed recently? Check to make sure the drain plug is tight and that no oil is leaking from the filter. BTW - Mine stays parked most of the summer while I drive the M3. I haven't had any oil leak problems.
about 2 weeks after my wife's A4 was serviced at 5000 she noticed drops of oil in the driveway.
next time in for another problem, I mentioned this, and found that during the service when the filter is changed some oil gets into a trough in the chassis and if not cleaned out by spraying brake clean, can spread all over the belly pan.
real mess to clean up, but that was the problem.
Just trying to help\
Tom
Tom
ltooz_a6_a8_q7
07-04-2005 02:59 PM
StreetCrawler(Cole)
06-13-2005 11:15 AM
