Oil filter spinning with oil cooler...help!
I figure using a channel lock but its an aluminum piece so it might break. **** if using the channel lock doesn't work is there anything else i can do?
Damn AutoEuropa for not tightening the nut on the cooler enough. (had a fender bender before and they did the work on the oil pan, oil cooler, and IC.
<ul><li><a href="http://www.sears.com/sr/javasr/product.do?cat=Hand+Tools%2C+General+Purpose&p id=00955653000&vertical=TOOL&subcat=Plumbi ng+Tools&BV_UseBVCookie=Yes">http://www.sears.com/sr/javasr/product.do?cat=Hand+Tools%2C+General+P
in between the oil cooler and some metal and it worked...i guess it wasn't so much the oil cooler was loose as the oil filter was way overtightened.
StreetCrawler(Cole)
06-13-2005 11:15 AM
