Oil leak question.... oil return lines at upper oil pan..should you use gasket sealer? TIA.
New rocker cover gaskets from Audi are $40 each and contain the gaskets for the spark plugs/coilpack seal too....
You've come this far - don't botch it now...
Alternatively, if it's coming from the heads, stop now and fix it!
Don't use instant gasket!
Best wishes,
Ram
Best wishes,
Ram
oil pan. It uses an O ring and has obe bolt that holds it on. I replaced the oring but it did not help.
