The oil pan , that thing on the bottom of the engine is covered in dried oil, I cant tell if its fro
from leaking valve cover gaskets, but Ive changed all those since then
is it pretty normal to have that thing all oily?
I think that is the source of this slight burning oil smell I cant get rid of( or does it not get hot enough)?
or is it "seal". I never know the difference...
Could be just about anything with the oil running down there or being carried and deposited by the belt.
screw something into it, maybe a quarter inch deep, the hole is on the pass side, maybe 1/8 in wide?
...that something else on the engine block is leaking
and you are getting dripping oil down there.
But the lower oil pan gasket is not so uncommon of
a repair. If I recall correctly, when I got the car
I had to replace that gasket and a turbo oil return
line o-ring seal. Seals can go bad just with time.
Also, pray to tha Audi gods that it is not a main
seal...
Next time post your milleage too.
seal...
RKA
21
03-15-2004 02:34 PM
