OK, first shot at graphing block 115.
I did a WOT run this morning. I noticed I was getting over 10 psi of boost (which seemed a bit high for stock) after installing the AWE gauge.
I think everything is normal except I am getting some pretyy high spikes at shift points. Is this normal? Any input?
This is a stock ECU, altitude approx 4,800 ft & it was 63 degrees. It was really hot yesterday (95+) & I was getting slightly higher readings on the gauge.
<img src="http://www.fankhauser.info/untitled.JPG">
Easy to test the DV's.
After DV is out of the car, push up on the piston with a pen or something. Push it all the way up and cover the nipple with your finger. The piston should stay up as long as the nipple is covered.
petervan
04-09-2006 02:05 PM
petervan
Performance and Tuning
04-09-2006 04:37 AM
MarkFank
23
08-26-2005 01:04 PM
bagodoosh
9
03-07-2005 06:36 PM
CharlieGSanD
08-30-2002 09:33 AM
