Ok, have the VAG hooked up to my car with the ABS light on. Can't connect at all with the ABS proble
Can't connect to either the engine controller or the ABS controller. While I was typing this, ABS light went off and I can connect to the ECU again.
So this looks like the ABS controller is messed up. Could this indicate a problem with the brake pedal position sensor or is the only solution to replace the ABS controller?
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8E0 614 111 A
Component and/or Version: ABS/EDS 5.3 QUATTRO D10
Software Coding: 0273004284
Work Shop Code: BB 24334
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
1 Fault Found:
intermittent. So the ABS and Brake lights will go on, sometimes stay on until the car is turned off, sometimes they go off on their own after a few seconds.
Doesn't appear to be related to braking, it can happen while just driving.
I had the same symptoms. When it dies, the VAG can't talk to it. If you remove.disconnect it, the VAG will work again. If you're doing this outside of warranty, expect to pay about $1000 installed.
seems a little ridiculous to have to pay for something like this
Omega Supreme
05-18-2008 02:59 AM
S4MarkS4
12-05-2005 10:48 PM
drpboston
07-22-2005 07:31 AM
