ok, i think i know why my car is FUBAR...
Alright, for those of you who don't know, my car is satan. While installing downpipes, I was forced to cut an O2 sensor wire in order to remove the old cats. I then removed the O2 from the stock cat using a crowbar (yes, it was on there tight) After getting the downpipes and test pipes on, i stowed the other post precat O2 sensor and left the wires on the drivers side one exposed (wrapped in tape). Well, today, i decided to splice it back together. After I spliced it back together, this whole mess of limp mode came on. thinking it was reversable, i removed the O2 again thinking I messed up the splice. After resetting the ECU, the codes came back almost immediately. I am thinking i shorted out my 02 sensors in some way, any idea of where I can locate this system or if I can isolate this and repair it myself, as I hate going to the dealer. Any helpful suggestions would be much appreciated. For those who dont know, here are all the codes i threw. Thanks for your input!!
17525 (P1117)---Unknown Trouble Code
17833 (P1425) Tank Vent. Valve Short to Ground
17938 (P1530)---Unknown Trouble Code
17955 (P1547)---Unknown Trouble Code
17529 (P1121)---Unknown Trouble Code
16486 (P0102) Mass or Volume air Flow Circuit Low Input
17861 (P1453)---Unknown Trouble Code
17865 (P1457)---Unknown Trouble Code
17523 (P1115)---Unknown Trouble Code
17527 (P1119)---Unknown Trouble Code
17697 (P1289)---Unknown Trouble Code
16518 (P0134) O2 Sensor Circuit No Activity Detected (Bank 1 - Sensor 1)
16538 (P0154) O2 Sensor Circuit No Activity Detected (Bank 2
