ok, my first misfire DTC...
3 DTC's Found:
16684 - Random/Multiple Cylinder Misfire Detected
35-00 - -
16690 - Cylinder 6 Misfire Detected
35-00 - -
car seems to be running fine, except that i've been thinking that boost is like 1-2psi less than normal.
no other errors.
Am i causing damage driving with this DTC?
Any leads or what to check next is greatly appreicated.
35-00 - -
35-00 - -
no other errors.
If its just an isolated incident, clear the DTC and see if it returns.
Could be a coilpack, could be ignition amp (output stage), could be sparkplug.
When were the plugs changed?
Try swapping the coil packs around and see if the misfires move. Repeat as necessary with igntion amps, sparkplugs, injectors to isolate the issue.
-Dave Pramanik
-Dave Pramanik
New plugs, new air filter, changed ignition amp,, net stop is to try swapping the coil packs. I have that code on cyl 1 and 3, in the warmer months I also get the EPC light. Driving me insane.
My question.. Can carbon build up in the Throttle Body cause EPC and Misfires?
Fast Euro
07-19-2008 07:43 PM
Leester
09-19-2006 10:03 PM
fourwheelslide
03-13-2006 04:43 AM
