Ok, new speakers or new speakers + new amp?
Old 08-24-2004, 10:45 PM
reza's Avatar
Default Ok, new speakers or new speakers + new amp?
so, I'm looking at replacing the rear two speakers with a pair of 2 ohm 6.5 inch speakers (which I hope will work with the amps that are currently attached to the speakers) or replace the pair with a good 4 ohm set (cheaper) and get a new amp for those two speakers. Does anyone know if the input to the amps (which are attached to the bose speakers) are RCA level, or already somewhat amplified?
I just want a solution that is going to sound as good as the factory solution, be more durable (not blow a 4th time), and be as cheap as possible.
Thnx,
reza
Old 08-24-2004, 11:29 PM
ZephyrS4's Avatar
Default These "should" work....
Image Dynamics CX6
6.5" MID-BASS SPEAKERS
150 WATTS RMS
SENSITIVITY: 91dB
FREQUENCY RESPONSE: 65HZ-4KHZ
MOUNTING DEPTH: 2.8"
SELECT 2 OHM OR 4 OHM
<img src="http://www.carmedia1.com/media/idq456.jpg"><ul><li><a href="http://www.carmedia1.com/en-us/dept_119.html">Scroll down to CX6 6.5 mid-bass speakers</a></li></ul>
Old 08-25-2004, 01:16 AM
reza's Avatar
I was looking at those earlier. Anyone have any experience with them?
Old 08-25-2004, 06:19 AM
Member
vegasS4's Avatar
Default You need to replace the amp as well
<center><img src="http://pictureposter.audiworld.com/12649/p1010005.jpg"></center><p>
Old 08-25-2004, 07:06 AM
Oo.et.oO's Avatar
i wouldn't say "need", but more like _should_. it'll sound way better than this bose garbage
Old 08-25-2004, 01:07 PM
reza's Avatar
Can i just replace the amps going to the rear speakers? Do the factory amps take line level inputs?
Old 08-26-2004, 05:56 AM
Oo.et.oO's Avatar
oh yeah, sorry. factory amps take line level inputs (so i've read, never confirmed) ask in audio
eisman.s4
09-29-2006 08:26 PM
Sixmudd
9
03-10-2005 02:09 PM
lower750
03-26-2003 01:23 AM
SweetAudiJuice
02-10-2003 08:04 PM
vert1go
10-20-2002 07:01 PM
Quick Reply: Ok, new speakers or new speakers + new amp?
