Okay what's up w/ my car now (Please read as I need info ASAP)?
AudiWorld Expert
Here are the logs I got just now after putting stock ecu in and running a throttle adaptation. I started the car and let it sit at idle for a little bit, but did not drive it. I thought I had a bad MAF per my old thread (linked). I'm seeing the dealer tomorrow morning to get my maf replaced, but they won't replace it if I don't have the proper codes. What shall I do? And a big TIA.
VAG-COM Version: Beta 310.0-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 A
Component: 2.7l V6/5VT G 0002
Coding: 06611
Shop #: WSC 06325
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D54
Coding: 00060
Shop #: WSC 06325
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 D
Component: B5-KOMBIINSTR. VDO D05
Coding: 02262
Shop #: WSC 00000
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 15176
Shop #: WSC 06325
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00012
Shop #: WSC 06325
1 Fault Found:
01539 - Headlights Not Adjusted
35-00 - -
Address 56 -------------------------------------------------------
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00117
Shop #: WSC 06315
End -------------------------------------------------------<ul><li><a href="https://forums.audiworld.com/s4/msgs/1547457.phtml">Original Post</a></li></ul>
Coding: 06611
Shop #: WSC 06325
3 Faults Found:
Coding: 0273004284
Shop #: BB 24334
Coding: 00060
Shop #: WSC 06325
Coding: 02262
Shop #: WSC 00000
Coding: 15176
Shop #: WSC 06325
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
1 Fault Found:
35-00 - -
Coding: 00117
Shop #: WSC 06315
plug maf back in. Proceed to dealer.
Do this only if you are reasonably certain it is a bad maf.
zeeborg
2.7T V6 Discussion
06-10-2013 06:36 AM
PKBlu::E30 Hunt
06-05-2005 10:01 AM
Random CEL, CEL has been on for a couple of days now and I have VAGed the car several times (more)..
mullarks
08-03-2004 02:22 PM
