ooooh, new pics/products/info on the STaSIS site!!
<center><img src="http://www.stasisengineering.com/images/MS_Kit2.jpg"></center><p><ul><li><a href="http://www.stasisengineering.com/suspension.htm">http://www.stasisengineering.com/suspension.htm</a</li></ul>
those are purdy! street sport now height adjustable koni c/o set. non-hyperco springs.
i believe he may be the first other than prototypes.
STREET SPORT
KONI Coil Over Kit: $1,195
-4 KONI sport dampers
-single adjustable (rebound), narrow band
-suspension disassembly required
for adjustment
-cadmium plated threaded steel
damper bodies
-height adjustable
-4 progressive rate KONI springs
(400 lb. spring rate)
-balanced and adjusted on
SPA damper dynamometer
for adjustment
damper bodies
-height adjustable
height custom valved koni's w/ progressive hypercos.
and now the track sports say "adjustable on the car" wonder if they made some changes to the front dampers . . .
you have to remove them to adjust. STaSIS: are you listening?? GroupBuy??
