Opnions/help needed: replacement component speaker system?
<center><img src="http://myspace-082.vo.llnwd.net/01205/28/09/1205069082_l.jpg"></center><p>Hello all, just got a 2001 s4 recently, and one of the speakers is blown. its the bose symphony (I hate Bose neway)
i was thinking about these, the Infinity Kappa Perfect 6.1
http://www.cardomain.com/item/INFPERFECT61?vq_id=none
but i have no idea how difficult the install is. any help would be GREATLY appreciated, thanks!
The Infinity's are good, but I'd also check out the Rainbow Audio SLC Series...
They have gotten very good reviews over on caraudio.com. Also they are a bit cheaper that the Infinity's. Low $200 range for the front components.<ul><li><a href="http://www.caraudio.com/forum/">http://www.caraudio.com/forum/</a</li></ul>
Re: Opnions/help needed: replacement component speaker system?
I put the 2 OHM seperates from Infiniti in the front, it was 5 1/4 and 1" tweeter.. Was pretty easy to fit in.. I was going to replace the BOSE amp but it now sounds sooo good I am perfectly happy...
The Infiniti 2 OHM seperates are like $150..
Do it and you will be HAPPY..
Re: look on some car audio sites......there are better things out there than those
The only reason I went with the Infiniti's is because they are a 2 OHM set up where most speakers are 4 OHM's and the BOSE amp is designed for lower impendence...
So, whatever you get, try to find a 2 OHM set up unless you plan on replacing the Bose amp soon..
Re: The Infinity's are good, but I'd also check out the Rainbow Audio SLC Series...
good feedback, thanks. im not sure if i want to replace the head unit because you lose all the displays and everything correct?
where are these 2ohm speakers u guys recommend? is it the Kappas? would u buy seperates or the component packages?
Infinity Kappa 60.7cs FREE Shipping
Component Speaker System
6 1/2" * Plus One Oversized Woven-Glass Fiber Cone * I-Mount M.M.D. Tweeter
rear deck/back seat
Fitment: fits fits
rear deck/back seat
Fitment: fits fits
TdrKing
11-09-2006 11:42 AM
pat33
03-12-2004 07:17 PM
pat33
03-12-2004 02:34 PM
TDrain
12-31-2001 04:29 AM
