Oval Bridgestone SO-3's or others?
Anyone else have this issue? My SO-3's are not as round as they should be and are inducing a async whump whump whump (I get an extra special sound with the sunroof open due to fluctuation in the air flow over the opening.) No alignment problem, but handling is not as good as it should be since contact is non-constant.
Have you run into this issue with these or other tires?
Re: A bad mounting job can cause shifted wire inside the tire....
Thanks all. Back to the tire dealer tomorrow to see if they just didn't balance them or the tires are not round or they're just smoking crack or all of the above.
redrocker55
S4 (B8 Platform) Discussion
03-02-2011 10:50 AM
schnellmb
04-18-2005 09:52 AM
BrendanB lllllllllll
06-10-2003 06:01 AM
