Over 2000 miles...Break In / Oil Change Question
Guest
Posts: n/a
I am having a hard time with the recommended oil change schedule. 8000 miles seems like an awful long time to leave the original oil in the car, so regardless of what anyone says about modern engine building processes, I am changing the oil at 2500 miles (probably at the end of this week.)
Here is the question...do I stick with dino-oil until the 8000 mile marker to "properly complete" my break-in, or do I make my switch to synthetic now?
Guest
Posts: n/a
What I've always heard is to allow the engine to completely break in before switching to synthetic oil. This could be a range from 1500 to 8000 miles depending upon what your manual or service dept. says. I'm not sure how much this apply's these days because Mercedes and BMW come with synthetic oil from the factory. I believe there's alot of break in that takes place at the factory before the engine is even put in the car.
Hope this helps
Hope this helps
Guest
Posts: n/a
A buddy of mine used to drain the oil every 6 or 8 or 10 thousand miles and put it in a can in the corner of his garage to "rest." He'd refill the crankcase, then, when the time was right, he'd drain that oil and replace it with the well-rested stuff. He'd mumble about particulates settling out, eternal viscosity, etc. Makes you compulsive oil changers shudder, huh?
Guest
Posts: n/a
Consumer Reports did a study of wear and oil changes (no-turbos as I recall) and found generally no advantage to changing more often than mfg recommends....as I recall they looked at engines with a microscope and found no meaningful differenc i wear.
Frank B
Frank B
Guest
Posts: n/a
that this S4 owner is lucky to be marrying someone who would come to this forum and ask for help like this! I hope everyone will chime in with some good ideas for you.
It is difficult to recommend one of the new performance chips. They have not been out long, and personal preference weighs heavily. It would be difficult to know which one he wants, and I don't think a gift certificate would be appropriate here.
Does he have a radar detector? If not a Valentine One would be a big hit. By most accounts, there is not a better one made. Check it out at valentineone.com.
